If I have a sequence for lights and have darks at the end is there a way to stop tracking when the lights are finished and then take the darks?
Thanks Rick
Thanks Rick
Hi Rick, I think the normal technique is to set the sequence to Park after the last Light event. This stops tracking for when you do Flats and Darks. It also lets you set up the part to point to your flat frame or whatever you use for flats.
