Description
I am using a trial version (4.1.0.827) and I have the following problem with the ASCOM Switch Device function. I load the driver and set the switches. but nothing is active (see photo attached).
I use the ASCOM_IPX800-Switch_v1.1.0.exe driver.
I have contact with other applications (photo switch) which shows that everything is OK in terms of the driver and its connection to the IPX800
Ascom 6.6 indicates that it has all the data (photo ascom)
On the other hand SGP clearly sees the driver and the 8 switches, with their denominations, but does not have the connection with the IPX800
does a trial version allow switches?
Thanks for your help, Philip
Dear Ken, thanks for helping me in this situation, To put it simply, two photos:
in one that comes from the HELP module of SGP, there is this figure
in the other which comes from my SGP (in test), there is this figure
The difference, that of the HELP shows that the connection is made, the other of my SGP in test, indicates that there is no connection, and this despite that the ASCOM IPX800 driver is functional.
And that’s the problem, Philippe Belgium
Oh, I understand. The first image you posted (from the help manual) is from the Control Panel. The image you posted from your SGPro is not the Control Panel, but rather the Equipment Profile Manager. The switch can only be connected and controlled via the Control Panel.
