Target End Time Not Honored
The “End at” time is ignored when there is a “Delay between” value set and the time falls in the count down interval. This is usually a minor problem but could be major if the delay is large.
Do you mean to say something equivalnt to:
“If SGPro is actively waiting between events as part of the defined delay, that SGPro does not stop waiting even when the target’s end time passes“??
I am staring at the code for this right now and the “between frame delay” does already implement checks to honor both target and sequence end times. This code was added to SGPro on Nov 23, 2024 and is included in the 4.5.1460 beta release here
Sequence Generator Pro 4.5.0.1460 (BETA) is Released for Test - Releases - Main Sequence Software
If you are using this version or better and still observe the issue, I’ll need logs to understand exactly what you see.
