Thanks for including C2A in the list of imports. It looks like the RA and DECs get imported ok. I find, however, that the first event (Target 1) is able to be populated but the objects loaded after that have blank fields and I can’t enter events. I normally delete the Target 1 object after importing.
Sorry, not 100% following this. You’re saying that from an empty sequence that has a target named Target 1 that it is OK, but none of the C2A imports allow adding events?
I replied from my phone. Not sure it got to you so I’m re-iterating.
Target 1 shows 5 events to be populated in the event fields (normal). The following targets show just a blank area there. I can’t add an event to get an event entry to show up to be populated.
I tried your latest version, 1530, to see if you’d fixed the blank events field when importing from C2A. Still doesn’t work. Add New Event doesn’t do anything although I can create a new target at the end and populate those events. Here’s what it looks like:
BTW, importing the Starry Night format does not work either. Same thing.
I had not gotten around to correcting this issue yet, but it is fixed now and will be in the next beta on Thu / Fri.
