I’m seeing an issue in the 3.1.0.258 beta in the targeting dialog - this one relates to the altitude calculation in the time constraints field.
Here I have a sequence that ran last night between the times shown in the screenshot. The next morning, I inspect the planner with an aim of setting up the sequence to run again, but the altitude calculation for the end time appears to be garbage (-90 degrees instead of approx 35). The tipping point comes (today - 30/09/19) at 02:51:00 - any time after this results in a -90 alt. before, it correctly reports (as per the cursor readout in the planning tool) as 53.3 degrees.
Sequence file (in zip) and screenshot attached.
SBIG LBN534.zip (6.4 KB)
