Hello!
I’m back to home imaging after remote imaging for over a year. It has been a long time since I’ve used SGP or my home observatory so I am out of practice with it…
I’m able to connect all my equipment but when I hit run, I get an “error initializing notification system endpoint “Text File 1” See log for additional details.” In searching through the forum I saw one post about this from 2016. Any idea what I need to fix? Happy to provide log file if needed. Thanks!
Logs may be helpful, but I can take a guess anyhow. SGPro is complaining that you have asked it to record logs to an external file named “Text file 1”. If you go to the external notification setup, you should be able to either uncheck the option or, in the case, that you need it, correct the issue (maybe a bad path).
