I upgraded from TheSkyX 32 bit to 64 bit. When I try to select TheSky 64bit in Device Settings the latest version listed is The Sky X Pro 10.2.0 or later, but this is not the 64bit version. How do I get the 64 bit version into TheSky Controlled Driver Setup?
I don’t have much experience with TSX, but it will install its own ASCOM driver that SGPro will find and display. If it’s not showing it seems like either TSX did not install it or it was not installed properly. You can also take a look at ASCOM diagnostics to see if it appears there.
In other words, in terms of what appears in the equipment dropdown doe Telescope, SGPro does not control. If you can convince TSX to install the (new?) 64-bit ascom driver into the ASCOM registry, SGPro will display it.
Have you installed the Ascom2X v 6.2 driver for your mount? You’ll need it for 64 bit operation.
