If I take a picture and have a look to the header infos,
Date is good but UTC and Local time have 2 hours more
PC is on local time and correct
Have you any idea where the problem is ?
Merci
JP
Merci
JP
Maybe check that your PC is set to the correct time zone. Probably is, worth a look though.
Can I ask in which time zone you are located?
Universal Time Coordinate (UTC) is basically the successor to Greenwich Mean Time. If you are somewhere in Europe your local time during summer I think is typically +2 hours versus UTC.
Here in UK during summer time I see +1hr difference between Loc time and UTC time. So basically I don’t think anything is wrong. The times you are seeing are exactly the same time but expressed for different time zones.
