Description
<Hello
I have a tracking problem with the ZWO AM5 mount or the Cartes du Ciel 4.3 software.
I also use the PrimaLuceLab Eagle4 Pro and Sequence Generator Pro 4.1 (SGP).
At the beginning the tracking function works on both the AM5 software (desktop) and on Cartes du Ciel (Skychart) - when i switch it on/off on one software, the other responds immediately, so far so good,
RA and DEKL buttons work with both software! I also did platesolving in SGP including solve & sync, also because Cartes du Ciel takes over the correction parameters for the RA and DEKL coordinates!
Problem: If I now want to pan from one object to another in SGP, it still works normally, but I can neither activate the tracking function in the AM5 software nor in Cartes du Ciel!
Only when I go to the HOME position and then target the second object does the tracking function work again (but only via the HOME position!)
HOME = aligned towards the Polar Star
PARK = Horizontally aligned
I would be very grateful for help!
Greetings, Daniel P.>
Link to Logs
Useful Info
OS: <Windows 10 Pro, Build 19045>
Ver: <4.4.1.1441>
