Is it possible to transfer my equipment and settings from version V3 to version V4?
Or do I have to manually type in the equipment info to V4?
Thank you, John
Yes, moving sequences, equipment profiles and user profiles to v4 from v3 is supported and happens automatically. Keep in mind that we do not support movement back in the other direction. For instance, if there was some reason you wanted to move back to v3, we do not gurantee that v3 will be able to use that data.
Okay Thanks!
I opened both versions, and yes, it’s there!
John
