Trick to track focus before sequence start
The UK is experiencing warm dry days and clear nights, with a huge range of temperatures. My RCT focus position moves appreciably with temperature and I noticed that, my first focus attempt is often skewed and I do not get a good V-curve. The second or third one is better (I’m using 11 points already). I tend to lose the first few frames to ok but not good focus.
It then struck me - I introduced a focus target before my timed imaging target, which finishes just before my imaging target starts. I set this to autofocus every 5 minutes, taking dummy frames inbetween. In that way, I can start my sequence several hours ahead of time and the focus will track the temperature changes, ready for my main imaging run.
Are you essentially doing this to keep your RC in focus before your target is at a position to be imaged? Is that the idea here? So you’re starting when it’s dark…but you’re not ready to be on target?
Sounds like an interesting way to work around it!
that’s it, precisely, :).
I like that idea. I am using a c11 edge and I have the same issue.
thx
john
