Trying to use Framing and Mosaic Wizard......issues
I finally decided to move from Ver 3 to Ver 4. However, when I try to use the Framing and Mosaic Wizard the box is to big … also, I cannot position it so that I can see the last option to “Create The Sequence” I am ready to revert back to Ver 3 where I did not have this problem.
Is there an easy solution?
The box is as big as you have it set to be in Step 2. I am unsure what you mean by too big. What do you expect it to be?
What resolution monitor do you have? SGPro 4 requires at least 1920x1080
https://help.sequencegeneratorpro.com/MinimumSystemRequirements.html
The Framing and Mosaic panel can’t be resized or moved giving me access to the tools at the bottom of the Frame & Mosaic panel. In V3 of SGB I couldn’t resize the panel BUT I could move it up enough to access the ability to create a new sequence/mosaic. I can change the resolution and all is ok but my 77 year old eyes would prefer I keep this res…which is the same res I had in the V3.
I would just like to be able to move or resize the panel to keep this res… and have access to the entire panel. I don’t care if the entire panel is displayed asl long as I could move it for access to all of the needed check boxes and selections.
This is not a step 2 issue - that is not a problem…it is a step 4 issue as I can’t get to the bottom of step 4 to create a new sequence. I can move the box down and out of the display but not up far enough to have access to all of Step 4.
