Hello! It would be helpful if SGPro calculated sunset/sunrise, civil twilight, nautical twilight, and astronomical twilight and allowed these to be used as part of a sequence start/finish times.
Typically, I want to image objects that are above 30 degrees from the horizon and to start/finish after astronomical or nautical twilight.
For example, when I am following a short period variable for photometry, I want to stop the sequence when nautical twilight starts in the morning. At that time, I’ll start my twilight flats sequence and then end the sequence.
Currently, I look up these times separately and input them into a sequence each time I might run it
Having the ability to tell SGPro to start/stop a sequence when it is above 30 degrees and that twilight has (or has not) occurred on that date would be useful.
Thank you and best regards.
