There’s a bug with the date, but not the one you described.
MMDD did actually change the month, but not the date, it should change to 0901 after midnight.
In my opinion it’s a good thing SGP is saving celcius in the filename, it seems very common for astronomy software to use celcius which is a good thing
No, that’s ok, was just curious… we can’t do anything about that log statement as the ASCOM focuser interface does not allow a way to query the temperature scale… since almost everyone uses Celsius, we just fudged it. If you were getting it from an environment device we might have been able to detect…
Ken, you might to reverse these. mmdd has always worked like m2d2 is proposed to work, except of course on the last day of the month. This will require everyone to change this parameter. That’s fine with me. Your logic is good, it will just make everyone make this change.
“mmdd” has never worked that way. That has always been current month current day. What you are referring to, I think, is “mmdy” which is current month, starting day. BUT, even though I pulled it out of the docs, “dy” is still respected so impact should be minimal.
According to the ASCOM specification the ASCOM Temperature property returns a number but there’s no current requirement that it must be Celcius or anything else. It’s just a number.
I’ve raised this with the ASCOM specification keepers, I think it needs a change to the documentaton saying that the temperature must be returned as C.
