I’ve been unable to get SGP to work as the image capture and plate solve software for the Astro-Physics APPM point mapper. The symptom is that, when I attempt to solve from APPM, SGP appears to take an exposure, but says “downloading image” for a very long time. Eventually, SGP says “API call complete”, but the camera image never appears in the SGP window, and APPM waits indefinitely and needs to be aborted manually.
This has always been an issue for me, going back a couple of years. I’ve been using MaxIm/DL as my capture software when I build a point model as a workaround. I’ve recently switched from an ASI1600MM-cool camera to a QSI690-wsg8, and I wanted to finally investigate the issue.
To reproduce the problem, I did the following steps:
- Started SGP and connected to all equipment
- Slewed to a target in the sky and took a sample image, which worked fine
- Did a “solve & sync” in SGP to ensure that plate solving works, which it did
- Connected APPM to SGP and the mount
- Attempted a plate solve from APPM and encountered the problem above
In looking at the SGP log, it appears that the problem happened here:
[03/09/20 03:53:42.415][DEBUG] [Camera Thread] ASCOM Camera Error : NumX set - '6776' is an invalid value. The valid range is: 1 to 3388. (System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Runtime.InteropServices.COMException: NumX set - '6776' is an invalid value. The valid range is: 1 to 3388.
--- End of inner exception stack trace ---
at System.Type.InvokeMember(String name, BindingFlags invokeAttr, Binder binder, Object target, Object[] args, CultureInfo culture)
at ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type[] parameterTypes, Object[] parms) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 443)
at ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type[] parameterTypes, Object[] parms) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 483
at ASCOM.DriverAccess.Camera.StartExposure(Double Duration, Boolean Light) in C:\ASCOM Build\Export\ASCOM.DriverAccess\Camera.cs:line 593
at sc.hy(ql A_0, sm& A_1, sm[] A_2)
[03/09/20 03:53:42.416][DEBUG] [Camera Thread] ASCOM Camera: Attempting to abort exposure...
[03/09/20 03:53:42.426][DEBUG] [Camera Thread] ASCOM Camera AbortImage: Camera state is 0
[03/09/20 03:53:42.426][DEBUG] [Camera Thread] ASCOM Camera: Camera state is idle, abort not needed...
I cross referenced the APPM log and here is the relevant log entry:
0000007 2020-03-09 03:53:17.545: Debug, SgProCam, Sending: http://localhost:59590/json/reply/SgGetCameraProps, Params: {}
0000008 2020-03-09 03:53:17.797: Debug, SgProCam, Response: {"Success":true,"Message":"Success","NumPixelsX":3388,"NumPixelsY":2712,"SupportsSubframe":true,"GainValues":["Not Set","High Gain","Low Gain"]}
0000009 2020-03-09 03:53:41.873: Debug, SgProCam, Sending: http://localhost:59590/json/reply/SgGetCameraProps, Params: {}
0000010 2020-03-09 03:53:41.914: Debug, SgProCam, Response: {"Success":true,"Message":"Success","NumPixelsX":3388,"NumPixelsY":2712,"SupportsSubframe":true,"GainValues":["Not Set","High Gain","Low Gain"]}
0000011 2020-03-09 03:53:42.089: Info, State Machine, Entering State=StartPlateSolveNow
0000012 2020-03-09 03:53:42.136: Info, State Machine, StartPlateSolveNow via SGPro PlateSolver: Starting Exposure=5
0000013 2020-03-09 03:53:42.171: Info, StartTakeImage, Sequence Generator Pro: Binning=2, Duration=5, IsDarkFrame=False
It appears that APPM never send anything to SGP that included an X parameter of 6776. The suspicious thing is that I have APPM configured to bin 2x2, and 6776 is exactly double the camera’s native horizontal size of 3388.
I have the full logs available. I don’t see how to attach them here, but I’ll see if I can do so after posting the topic…
I am using the following versions:
- SGP version 3.1.0.404 (although I had the same problem in 2.x)
- .NET framework version 4.7.2
- APPM version 1.7.1.5
Thanks for any suggestions,
-Wade
