Hi! I think I found a bug in SGP 2.6.0.23.
I deleted the only target in my current sequence, making the sequence empty. I then ran “Solve and sync”, and after succesfully solving the current position I got an unhandled exception. I did not make note of the exact error message, but I figured it was because the sequence was empty. When “Solve and sync” is succesful, a window pops up telling the solved coordinates, confidence and a dropdown menu for using the results as a reference for a target. That dropdown menu is populated from the targets in the current sequence, and I’m guessing SGP does not check if the sequence is empty.
