Okay.
A request for help from the braintrust on these forums:
I had clear skies last night and tried out the ASTAP HFD routine for autofocus, with min quality set to 96%. I use a Tak FSQ106 on a 10Micron mount, with an SBIG 16803, with 9micron pixels and 3.5" sampling. The night started out well with autofocus working perfectly. But at around 11pm at night, autofocus appears to have failed, with focus run after focus run hitting 94%/95% but rarely 96%. This was true across a range of filters. Sometimes, even when it hit 96%, it appears to have reported as a failure and restarted the focus process (see, for eg. the log excerpt below). Often, the curve would show 98% through 8 points, and then drop below 96% on the last point.
The skies appeared clear, and the few images that were taken show no signs at all of clouds.
Any ideas as to what might be going on here? I haven’t had this problem before, when using HFR (might be unrelated, but is the only thing I changed). Do the step size settings need to change when using ASTAP-HFD? Is there some other setting I might need to adjust?
Link to full log:
https://1drv.ms/u/s!AsHXUvMw3K77gdwIbv7OhSVtrflGwA?e=OEAjjq
01/12/21 03:50:23.209][DEBUG][Camera Thread][SQ;AF;] Auto focus HFD calculated at: 5.36 with 217 stars
[01/12/21 03:50:23.213][INFO][Camera Thread][SQ;AF;] Incremental Fit Result (9): quality=96%; a=0.559543021081803; b=-20.7445317759284; c=194.294176443565;
[01/12/21 03:50:23.220][DEBUG][Camera Thread][SQ;AF;] Emit AFPack screenshot: Points: 9; Final: False
[01/12/21 03:50:23.220][INFO][Camera Thread][SQ;AF;] Detected focus getting worse! Shifting auto focus range
[01/12/21 03:50:23.272][DEBUG][Main Thread][SQ;AF;] Adding sequence level notification: Cannot find focus point, assuming focus is outward, adjusting smart focus range…
[01/12/21 03:50:23.297][DEBUG][Camera Thread][SQ;AF;] Sending Notification: Warning - Cannot find focus point, assuming focus is outward, adjusting smart focus range…
[01/12/21 03:50:23.297][DEBUG][Camera Thread][SQ;AF;] Handling monitoring event (Email 1, Warning): (Pleiades-Rosette-Focus Runs) Cannot find focus point, assuming focus is outward, adjusting smart focus range…
[01/12/21 03:50:25.263][DEBUG][Main Thread][SQ;AF;] Adding sequence level notification: Focus cannot be determined. Moving to start position of 18702 to reattempt. Fit Quality 96%
[01/12/21 03:50:25.285][DEBUG][Camera Thread][SQ;AF;] Sending Notification: Warning - Focus cannot be determined. Moving to start position of 18702 to reattempt. Fit Quality 96%
