Looks like the driver got into a weird state. Lots of these exceptions are found throughout the log. Guessing that if somewhere along the line the driver was power cycled or a non-ASCOM driver was used it may have reset things.
[07/27/20 20:52:55.343][DEBUG][CP Update Thread][NONE] ASCOM Camera: Error in GetCoolerTemp. : value of CCDTemperature is invalid. (System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Runtime.InteropServices.COMException: value of CCDTemperature is invalid.
--- End of inner exception stack trace ---
at System.Type.InvokeMember(String name, BindingFlags invokeAttr, Binder binder, Object target, Object[] args, CultureInfo culture)
at ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type[] parameterTypes, Object[] parms) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 243)
at ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type[] parameterTypes, Object[] parms) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 284
at ASCOM.DriverAccess.Camera.get_CCDTemperature() in C:\ASCOM Build\Export\ASCOM.DriverAccess\Camera.cs:line 126
at so.gr(Boolean A_0)
I’ll reload 3.1.0.539 and see if the problem is still there. When the error was occurring, SGP was apparently reading the QHY ASCOM driver, opening the camera settings from the “Equipment” panel on the sequencer form appeared normal. Changing nothing else, I switched to another program (APT), connected the camera, and started the cooling cycle. The power curve was “normal”. I then reloaded v 3.1.0.478 (making no other changes), connected the equipment and the camera cooled correctly.
I’ll let you know what I find when I reinstall 539.
