Viking switches
Hi, I been a long user of SGP and love the program, but I have this issue that I have never been able to use SGP switch to access Viking relays. Currently I use Viking to connnect to Lunatico Dragonfly Relays for my observatory that is totally automated using NINA.
Basically in NINA I set the switches to connect to Viking and thats it.
So, my question to anyone that have a similar setup , Can I achieve the same in SGP, in SGP I connect to Viking but thats it, how can I program SGP to automated my Observatory, do I need a script in this case?
Charles
You don’t need a script to accomplish this (I think?.. unless I misunderstand the question). To configure this behavior, you’ll just want to set the switches you need to the values you need in the “start state” column (switches tab). Then, assuming that one or more of these switches provides power to devices, you’ll likely want to provide a delay to allow for power cycling.
In addition to this, you can also specify an order that switch state should be set (and also provide custom delays between specific switches.
This is all currently available in the SGPro 4.4.1 Beta (essentially ready for release). If this is what you are looking for, I can dig out the post where I sent out the temporary beta docs.
