Description
I am unable to get a successful unattended meridian flip with using SGP with APCC and my 900GTO mount. I am trying to configure the most basic meridian flip possible (no customized meridian tracking limits in APCC).
What is the recommended configuration for SGP and APCC to do this?
Link to Logs
Relevant SGP log section is here:
[03/18/24 02:50:11.140][DEBUG][Sequence Thread][SQ;] Running capture event…
[03/18/24 02:50:11.142][DEBUG][Sequence Thread][SQ;] Attempting mount startup…
[03/18/24 02:50:11.175][DEBUG][Sequence Thread][SQ;] Mount startup good, reports not parked and tracking…
[03/18/24 02:50:11.181][DEBUG][Sequence Thread][SQ;] ------------- Starting capture frame for event[2] -------------
[03/18/24 02:50:11.182][DEBUG][Sequence Thread][SQ;] Sending commands…
[03/18/24 02:50:11.182][DEBUG][Sequence Thread][SQ;] Starting generic timed monitoring event for “Timeout! Error setting FlatBox position or brightness.” (THIS IS NOT AN ERROR MESSAGE)…
[03/18/24 02:50:11.182][DEBUG][Sequence Thread][SQ;] Clearing timed monitoring events…
[03/18/24 02:50:11.283][DEBUG][Sequence Thread][SQ;] Current timed monitoring events cleared, start new timed event “Timeout! Error setting FlatBox position or brightness.” (NOT AN ERROR)…
[03/18/24 02:50:11.283][DEBUG][Sequence Thread][SQ;] SetFlatBox: Frame Type is Light
[03/18/24 02:50:11.283][DEBUG][Sequence Thread][SQ;] EventMarker(2) - t:M51 (0); e:2; f:6; o:
[03/18/24 02:50:11.283][DEBUG][Sequence Thread][SQ;] Starting generic timed monitoring event for “Timeout! Error executing meridian flip.” (THIS IS NOT AN ERROR MESSAGE)…
[03/18/24 02:50:11.283][DEBUG][Sequence Thread][SQ;] Clearing timed monitoring events…
[03/18/24 02:50:11.484][DEBUG][Sequence Thread][SQ;] Current timed monitoring events cleared, start new timed event “Timeout! Error executing meridian flip.” (NOT AN ERROR)…
[03/18/24 02:50:11.484][DEBUG][Sequence Thread][SQ;] Checking if Meridian Flip is needed
[03/18/24 02:50:11.485][DEBUG][Sequence Thread][SQ;] Telescope is on the West side of the mount
[03/18/24 02:50:11.486][DEBUG][Sequence Thread][SQ;] Presenting wait for meridian dialog…
[03/18/24 02:50:44.545][DEBUG][Main Thread][SQ;] FlipWait: ending wait due to telescope parked or not tracking…
[03/18/24 02:50:44.551][DEBUG][Main Thread][SQ;] Adding sequence level notification: Terminating meridian flip! Telescope is no tracking.
[03/18/24 02:50:44.584][DEBUG][Sequence Thread][SQ;] Sending Notification: Error - Terminating meridian flip! Telescope is no tracking.
[03/18/24 02:50:44.584][DEBUG][Sequence Thread][SQ;] Handling monitoring event (Good Night System, Error): (M51 - 2024-03-15) Terminating meridian flip! Telescope is no tracking.
[03/18/24 02:50:44.584][DEBUG][Sequence Thread][SQ;] GNS: Sent error message to GNS ((M51 - 2024-03-15) Terminating meridian flip! Telescope is no tracking.)…
[03/18/24 02:50:44.591][DEBUG][Sequence Thread][SQ;] Aborting sequence: Terminating meridian flip! Telescope is no tracking.
[03/18/24 02:50:44.592][DEBUG][Sequence Thread][SQ;] Set sequence abort
[03/18/24 02:50:44.592][DEBUG][Sequence Thread][SQ;] AbortSignal “Global Abort Signal” set to True by Sequencer.SetSequenceAbort
[03/18/24 02:50:44.592][DEBUG][Sequence Thread][SQ;] AbortSignal “Global Abort Signal” check; value is True
[03/18/24 02:50:44.592][DEBUG][Sequence Thread][SQ;] EventMarker(3) - t:M51 (0); e:2; f:6; o:* aborted *
[03/18/24 02:50:44.592][DEBUG][Sequence Thread][SQ;] EventMarker(10) - t:M51 (0); e:2; f:6; o:* aborted *
[03/18/24 02:50:44.592][DEBUG][Sequence Thread][SQ;] AbortSignal - RaiseAbortSignal for “Global Abort Signal” already active…
[03/18/24 02:50:44.593][DEBUG][Sequence Thread][SQ;] AbortSignal - RaiseAbortSignal for “Global Abort Signal” already active…
[03/18/24 02:50:44.593][DEBUG][Sequence Thread][SQ;] AbortSignal “Global Abort Signal” set to True by Sequencer.RunSequence-2
[03/18/24 02:50:44.593][DEBUG][Sequence Thread][SQ;] Run event requested sequence abort…
[03/18/24 02:50:44.595][DEBUG][Sequence Thread][SQ;] ********* Run post sequence *********
Useful Info
For configuration, please see attached screenshots
OS: Windows 10
Ver: 4.3.0.1305
