Because SGPro v2.5.1.17 can’t run multi objects click here , so I’m using v2.5.1.16, it cooperates with PHD v2.6.2. these days, I found they can’t work stably, there are three problems at least.
1 . Center function often can’t execute PS2 then suspended when SGPro is deactivated, often occur at the beginning of sequence, and in the recovery mode is also very prone to.
A sample of at the beginning of sequence:
The log file:sg_logfile_20160902224445.zip (10.2 KB)
A sample of in the recovery mode:
The log file:sg_logfile_20160902222238.zip (10.2 KB)
2 . PHD Camera connection timeout
This is a question still bothers me, from the initial, whether it is the default 15 second timeout, and set the timeout to 60 seconds or 180 seconds, PHD always told me that in 16 seconds, 61, 181-second timeout, and then disconnected from the camera (SGP API) connections, followed by SGPro cancel task sequences.
Recent particularly frequent, I simply cannot take it anymore.
3 . Dither bound to fail in recovery mode.
By the way, there is also a problem, though probably not SGPro problem, but still uncomfortable: PHD often lost the guide star, although the sky is quite clear. This waste me several nights.
I feel tired these days, every morning when I wake up, SGPro will give me the bad news. I expect a stable version SGPro, especially part of the collaboration with PHD, and perhaps it is time to consider writing own guiding program.
Please help me, thank you ~
