I have recently set up a Hyperstar with filters being loaded manually via a filter slider from Starizona. I set up the sequence so that it stops between filters, gives me a message to change the filter and then does an autofocus on the resume. All good.
However, I was unable to specify the filter in the sequence. If I did, I got an error message saying that a filter wheel is required and the sequence would not proceed. I had to work around the issue by putting the filter name as a suffix. That doesn’t seem logical to me. I ought to be able to specify a filter name without having a filter wheel connected
What is the best practice here?
Thanks, Niall
Useful Info
OS: Microsoft Windows 10 Pro
Ver: 4.0.0.680
.NET: 4.8
ASCOM: 6.5.1.3234
