Can we get a sneak preview of what’s coming in V4.0 somewhere yet?
Just installed the new licensing system, and about to subscribe, but it would be nice to know what’s coming down the line to get us all excited :).
A 64bit version for starters
That’ll help all those QHY users with the leaky drivers that cause out of memory crashes at least
When does V4 release and will it have a fix for the ASI6200 download issues?
Yes, a 64bit version is coming with v4. Also Switch support. For the ASI I need to test that against the 64bit version but it’s likely to address the issue.
“Switch support” ??
helps you switch from NINA to SGP
I would also like to know if V4 will have a fix for the ASI6200 download issue.
Support for the ASCOM Switch Interface (turning things on and off basically).
I’m assuming the 64bit version will address this but still need to test.
Does this mean my ASCOM devices that are 32bit (not available in 64bit) will cease to work? Off the top of my head I know my QHY8 is 32bit… don’t really want that one going away!
There will be a 32bit and 64bit version. You can choose one or the other depending on what you need…so you’d have to stay on 32bit. I’m in the same boat with my QHY11. Most more modern drivers support both 32 and 64 bit.
Jared,
Beyond a 64 bit version, do you have a specific list of improvements and features in Version 4? This would provide more incentives for users to move to the subscription model vs. stay on V3 or migrate to NINA.
Mark W
I don’t understand what makes 64bits interesting while the best cameras just get 16bits sensors.
No, because there is not a exhaustive list as we’ll be continually updating V4 from now on vs holding back features for major release. V4 is likely to be our last version number of SGP that we release…that does not mean that we stop developing it…that just means that we continuously will push features into V4 and will not create a V5 as there is now no need. The initial release of V4 will include:
It is not a particularly large release other than the 64bit support.
This has nothing to do the bit depth of sensors. Currently SGP is a 32 bit application and as such can only access a limited amount of memory (about 4gigs). Moving to a 64bit application will allow SGP to access more memory as well as interacting with 64bit drivers (probably the main benefit). This means that things will generally be faster and have less issues with large camera arrays.
Other things that we have discussed for SGP4:
64bit
ASCOM Switch Support
Auto Focus Wizard to help setup auto focus
Performance improvements around download/save/display of images.
I like that !
Jared,
Will there be an easy way to tell what drivers need to be changed from 32-bit to 64-bit? I’d like to go with 64-bit when it is available, but I will need to know if my equipment will work. Also, will ASCOM 6.5 be required?
Dale
I also need to know if SGP4 requires ASCOM 6.5? I am still operating on ASCOM 6.4 and won’t upgrade until the platform is completely stable and compatible drivers are available for all my equipment. Most of my equipment is modern so I fully expect compatible drivers to be available.
I agree there needs to be a way to know whether installed drivers are 32 bit or 64 bit. It is my understanding 64 bit apps require using 64 bit ASCOM drivers. Is that true?
The download page indicates SGP4 will also be available as 32 bit. Is that true? If so, does that mean it will be fully compatible with ASCOM 6.5? I’m still am not sure all my current ASCOM drivers will work in the new 6.5 platform.
Is it possible to draw ,in the preview screen, an area corresponding to the different sensor size?
I mean a rectangle/square for APS-C , or 1", or APS-H , ecc selectable in a list of choice based on smaller sensors then what configured in camera settings.
I have a full frame camera and i would have found it very useful , mainly to verify the effective
corrected area by flattener/reducer , comparing full frame area to smaller one ; useful to select
subarea focus too, instead drawing by hand.
Franco
This is the best explanation so far. A reason to Sub now. Thanks for that. Did I hear an autofocus trainer? That’s awesome. Would love a “object” widget (Kind of like the one in Voyager) so I can pin to a toolbar to see when the target transits and such. Also would love a DARK mode!!!
Keep up the great work!
