Also, why doesnt it give some error message when failing to download image?
The scenario is this:
Intel NUC with 64bit win7
newest ASCOM and SGP
some other ASCOM stuff, ASA mount, scopeDome, lakeside focuser and SX filterwheel.I dont use guider.
The camera is atik 460ex.
I start the focus and frame loop which runs fine for a while, after some time frame and focus-image doesnt get updated but is forever showing "downloading"
Have to use process handler (correct term?) to shut down SGP.
Might be an Ascom problem for sure but shouldnt SGP at least give some error indication?
Wherever the problem might be, does anyone have some suggestion for tracking down this error?
Its a permanent setup so Cables shouldnt be the problem, if I kill SGP and restart it, it works again for a while.
I’m pretty sure this error only occurs when other stuff is connected to USB-hub, at least I never been able to reproduce it if the camera is the only thing that is connected to Ascom.
I say “pretty sure” because I never been able to reproduce it when “running dry”, daytime for example. The error only occurs when it’s very annoying.
Pelle
