ZWO 224 camera fails to connect via ASCOM - need to reset camera device list
I have a ZWO 224MC which I’d like to use with SGP. I installed the ASCOM driver and this appears as an option in the camera drop-down list, and I can connect to it and set the camera gain etc.
However, I can’t actually capture anything with the “frame & focus” tool or the main sequence. The camera works via SharpCap.
Any suggestions?
I did notice that two ASCOM entries appear in the drop-down. Could the ASCOM driver installation be corrupt?
John Wheeler
[Update to my earlier post]
ASI ZWO camera ASCOM woes…how do I delete & start over?
The camera works well with its native driver, and is supported by planetary capture apps such as FireCapture or SharpCap.
I would like to use it with Sequence Generator Pro, which only supports ASCOM drivers for ZWO cameras. At some point my ASCOM installation got into a mess, and now the ZWO camera appears twice in the list of cameras in SGP (“ASICamera (1)” & “ASICamers (2)”.
Until I messed around with it today, I was able to connect to these cameras, but not capture (it would just hang during “downloading”). The same applied to connecting via ASCOM in SharpCap, so I have ruled out a specific problem with SGP.
I eventually uninstalled the ASCOM drivers & the ASCOM platform, and then had a purge of all working directories related to ASCOM (e.g. ProgramData/Common Files, /Documents) and got rid of lot of entries related to the cameras in the Windows registry.
Maybe this last step was a bad idea, because now I can’t even connect to the camera at all via ASCOM. I just get a “ASI camera not detected” error in SharpCap, and something similar in SGP. Despite my efforts to purge all mention of the cameras, both still appear in the drop-down lists of SGP and SharpCap.
Short of nuking Windows and starting over (), does anyone know how I can reset the ASCOM device list and just re-install the ASCOM drivers? Simply uninstalling ASCOM does not do this. Maybe I should also uninstall SGP & SharpCap?
I’d be interesting in understanding how and where the camera settings are stored, and whether there is any kind of admin console for managing ASCOM devices.
Thanks!
John
