Hi! I’m attempting to use my ZWO EFW filter wheel in the latest SGP after previously using it in SGP a couple years ago and getting an error.
Log file (check the end): https://easyupload.io/l5lusa
I can configure the filter wheel from within the Sequencer ‘Equipment’ dialog before I click ‘Connect’ and I’m able to change filters within the wheel (audibly hearing the change) and configure names, etc.
Once I click ‘Connect’ via ‘Equipment’, the Connect Icon turns green. Then when I click into device settings, the ZWO dialog says “Failed to run to the specified position”, etc. Upon closing the dialog, when I try to click back into device settings, I get “This EFW is removed”. After I disconnect, I’m able to go back to successfully configuring through device settings.
First click of Device Settings
Second click of Device Settings
