I currently use an Alnitak flipflat for taking flats, and it works great when I have only one target for the evening. For example - I shoot target A light frames, then shoot flats. Everything works as expected - when the light frames are done, it closes the panel, sets the panel to the specified brightness and shoots the number of exposures I defined.
My problem: Sometimes after shooting target A along with the requisite flats, I want to go shoot target B. Upon completion of target A flats, the flat panel is still covering the scope, and I do not know how to get it to open without going to the SGP control panel and clicking on the OPEN button. What I have been doing is having the sequence āpauseā when completing target A so that I can manually open the panel. But there has to be a way to have that happen automatically, no?
This is my problem too at the beginning of a session - when I connect everything the flat panel is closed and I have to āmanuallyā open it before I can start a sequence. What am I missing to automate the flat panel open and close process? Oh - it does close at shutdown no problem.
Thanks in advance
Frank
