Sequence Generator 4.1 has been released! There is a ton of new and cool stuff available, but, if you’re reading this post it’s probably because you use Good Night System (GNS). Here’s what you need to know:
Starting with version 4.1, SGPro will no longer distribute any version of GNS with its installer. This means that your GNS notification endpoint will fail until you install the latest version of GNS from LunaticoAstro.
If you are using SGPro 4.1, please ignore the link for “Update for SGPro Users”
I’m currently adding a quick check on sequence start that will determine if you are in this situation and provide adequate warning.
