I have successfully run two sessions of SGP so I can run two cameras in master/slave mode. The primary runs the first camera and controls the mount and dither, etc. The second session runs my WF and just takes images and through out what is not good due to dither or meridian flip, centering etc. It has worked numerous times. I have been following multiple threads on the desire for full 2nd camera support, I count me as #8, but this is not about any request for major upgrades to SGP. This is an error issue. Now I cant get the 2nd session to even start. It errors out and just sits there at the opening stage. I have screen captures of the dialog boxes that come up and here is the error log:
I will do a post on CN so that I can post the images, but I dont see how to do that on the forum. Please help.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: DragDrop registration did not succeed. —> System.Threading.ThreadStateException: Current thread must be set to single thread apartment (STA) mode before OLE calls can be made. Ensure that your Main function has STAThreadAttribute marked on it.
at System.Windows.Forms.Control.SetAcceptDrops(Boolean accept)
— End of inner exception stack trace —
at System.Windows.Forms.Control.OnHandleCreated(EventArgs e)
at System.Windows.Forms.Form.OnHandleCreated(EventArgs e)
at System.Windows.Forms.Control.WmCreate(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmCreate(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.3131.0 built by: NET472REL1LAST
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Sequence Generator
Assembly Version: 3.0.2.94
Win32 Version: 3.0.2.94
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/Sequence%20Generator.exe
System.Configuration
Win32 Version: 4.7.3056.0 built by: NET472REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
Win32 Version: 4.7.3110.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ServiceStack
Assembly Version: 3.9.48.0
Win32 Version: 3.9.48.0
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/ServiceStack.DLL
ServiceStack.Interfaces
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/ServiceStack.Interfaces.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Serialization
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
Newtonsoft.Json
Assembly Version: 4.5.0.0
Win32 Version: 4.5.8.15203
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/Newtonsoft.Json.DLL
System.ComponentModel.DataAnnotations
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll
System.Xml.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Data
Win32 Version: 4.7.3120.0 built by: NET472REL1LAST
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
RestSharp
Assembly Version: 100.0.0.0
Win32 Version: 105.2.3.0
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/RestSharp.DLL
Anonymously Hosted DynamicMethods Assembly
Assembly Version: 0.0.0.0
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
ServiceStack.ServiceInterface
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/ServiceStack.ServiceInterface.DLL
ServiceStack.Common
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/ServiceStack.Common.DLL
ServiceStack.Text
Assembly Version: 3.9.45.0
Win32 Version: 3.9.45.0
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/ServiceStack.Text.DLL
System.Web
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
ASCOM.DeviceInterfaces
Assembly Version: 6.0.0.0
Win32 Version: 6.3.0.2831
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.DeviceInterfaces/6.0.0.0__565de7938946fba7/ASCOM.DeviceInterfaces.dll
GraphLib
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/GraphLib.DLL
MediaSlider
Assembly Version: 1.3.0.0
Win32 Version: 1.3.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/MediaSlider.DLL
System.Data.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Data.Linq.dll
System.Windows.Forms.DataVisualization
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
System.Management
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
ASCOM.Utilities
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Utilities/6.0.0.0__565de7938946fba7/ASCOM.Utilities.dll
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.7.3056.0 built by: NET472REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
ASCOM.DriverAccess
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.DriverAccess/6.0.0.0__565de7938946fba7/ASCOM.DriverAccess.dll
ASCOM.Astrometry
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Astrometry/6.0.0.0__565de7938946fba7/ASCOM.Astrometry.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
