Hi support,
New user here. I can track, plate solve and sync, and run simple sequences. I tried to use the “Center Here” command from the context menu on a bright star in my captured exposure. It starts the plate solver (PlateSolve2, which works great normally, quick and perfect fit every time so far) and goes for many minutes and then fails and switches to the blind solver (Ansvr). The latter just quits after a few seconds with no action or error messages.
We’ll probably need a log to help here. But I would guess that the hint data is incorrect or if it’s a REALLY bright star then the solvers may have issues with it as the surroundings are somewhat blown out. You can also try shorter exposures if that’s the case.
