I cannot connect my Canon EOS 850D in SGP. I use the M mode and Bulb. I also don’t get a connection with an EOS 850 D. When I try to connect, SGP shut down. However, both can get a connection in Backyard EOS and in APT. Who can help me?
François
What version of SGP are you using? If you’re using one of the 4.0 versions can you attempt 3.2 and report if that is successful. Some of the driver architecture for canons changed in 4.0.
Also a log would be helpful as well.
Thank you,
It is OK wen I use the 4.0.0700 32 bit
Francois
What is the version of SGP are you having problems with?
Thank you,
The same version: 4.0.0700 but then the 64 bit.
Francois
It was the EOS 850 D, Not The 550 D.
Ah, this is helpful. I’ll double check the driver versions between them. But they should be the same.
Thank you,
