Xplode, I am getting nowhere with you and would ask that you refrain from replying as you obviously don’t have the capacity to understand the issue.
I am not a beginner and have a good few years experience, so don’t try to preach when you don’t understand the problem. I am always ready to accept when I am wrong and apologise, but in this instance the suggestion from Jared is not working.
Just for others I will spell out the problem and the issue.
Problem
SGP at the end of a sequence or if the sequence aborts due to a lost star, will bring up the recovery dialogue box as per this image: -
Jared replied to say that this can be disabled if you uncheck this box as he thought I may have enabled it, but the fact is I haven’t and never have enabled it: -
This was the capture before commencing my sequence, clearly showing that I have not enabled the setting: -
Why I want to disable it
I have a cloudwatcher system that watches any potential bad weather, this is the link: - https://lunaticoastro.com/aag-cloud-watcher/
Currently as I am unable to disable the shutdown and disconnection of my equipment, it means recommencing cool down etc.which I do not want to happen, there is no reason to disconnect the equipment with my settings, so I want to disable the function, but the function shown does not work.
Another reason for wanting it to function correctly is that frequently I will do my flats at the end of a session, so why switch things off when I need to continue using the equipment.
That is the issue, purely and quite simply a function within SGP does not work as intended, end of.
