Error with the alignment of the EQ6pro mount
"Good morning everyone, I have an issue that occasionally reoccurs with my EQ6 Pro. I’ll give you an example from last night or previous nights. I set up a sequence on M31 until 1:00 AM and programmed it to move to the Horsehead Nebula from 11:00 PM onwards if M31 was done, or to move there later when M31 set. When I check in the morning, I notice that it completed the sequence on M31 correctly, but there are no images of the Horsehead Nebula, as if it couldn’t align to it. I’ve updated the encoders, even though they aren’t necessary, and I use EQMOD. Does anyone have any suggestions?
EQMOD has an insane number of settings and, unfortunately, it’s very easy to get wrong (wrt SGPro compatibility). We don’t have or use EQMOD-based mounts, but we do try to keep a general EQMOD + SGPro checklist available for those that do:
https://help.sequencegeneratorpro.com/UsingEQMODwithSGPro.html
If this doesn’t help, we’ll need to get logs showing the issue. From logs, we can avoid having to ask you dozens of questions about your rig. Here is some general guidance on how to send us logs:
SGPro - Help
i send log file you can find it in this post Error pointing eq6
Good morning, everyone! Have you been able to check the program logs? Do you have any advice for me?
