See below. I entered the explanation a second time.
Guidance for log submission is here:
This is a repost that I’m submitting from the SGP Help menu so that I can attach the log file. The following is probably a duplicate message. Wasn’t sure what would display.
I have set up a sequence to cycle through all filters multiple times to derive offsets for autofocusing. The filter wheel is not advancing between images, or doesn’t appear to be according to the filter wheel panel. It stays on Luminance. I have checked “Rotate through events”.
I’m running with Windows 10
SGP version is 4.0.0.700
Link to Logs
Approx time of issue: 9/25/2022 5:44 AM
Useful Info
OS: Microsoft Windows 10 Home
Ver: 4.0.0.700
.NET: 4.8
ASCOM: 6.6.0.3444
If you’d like to submit logs showing the issue, we’ll take a look. The logs attached do not show any attempt at running a sequence.
A couple notes:
- I looked at the sequence attached and, assuming it the one you referenced above (polaris), I don’t see any issues with the sequence itself.
- The version of SGPro you are running is quite old and has a defect that might create very large log files.
