How to Submit Logs in SGPro
Hi folks,
Please help us keep support requests organized so we don’t drop them.
  • Support requests go in here: #sequence-generator:sgpro-support Please try to create them in there. We will try to help move them in there also.
  • We spend a lot of time asking for more data. If you create a topic in here, we provide a template to help guide the support request.
There is a new option in the Help menu. The “Report a Problem” item will open up a new ticket for you, provide required information and a template. It is here:
Then following the numbered steps in the image below…
  1. Type the subject of a new issue OR if you are trying to add to an existing issue, use the dropdown menu to find the topic to which you’d like to append.
  2. Type out the details of issue you have observed.
  3. Click one or more logs that show the issue (note the column with the date and time).
  4. Choose an approximate time of the issue (or the first occurrence). It doesn’t need to be exact.
  5. Click Submit
At this point, SGPro will offer to show you the new topic or message in the forum.
Notes
Sequence slews to next target before set start time
Problem witn “Target Settings”
SGP will crash when use with Canon EOS
Integration does not start
Sequence does not move beyond the first filter
Pegasus Astro Ultimate Powerbox V2
PHD2 not guiding after First image
SQ Pro freezing
Resuming the autoguider + +
Sequence freezing and auto focus
Plate solving annimage works but centering fails?
Plate solve2 not connecting in SGP
Celestron Focus Motor disconnect
Failed meridian flip with APCC and SGP and AP900 mount
Frame and Focus error on download
QHY 268M offset per event
Center here function
Beta release probs
SGP-Hangs During Mount Calibration sequence step
SGP 4.1.0.761 - Pegasus UPBv2 Switches issue
Major issues with 4.1.0.744 & .750 betas
SGP stops with Nikon D5500 dslr!
ASI/ASCOM Connection Issue
776 Bug: Delay on sequence options
QHYCCD Filter Wheel
Alnitak Flipflat - using across multiple sequences
STT8300 Self Guiding Filter Wheel+SGP+PHD
Frames and focus keeps cycling
Problem generating flats when event not completed
Problem auto center after meridian flip
SGP 4.1.0.793 Failed to end sequence on time
Sequence Aborted Meridian Flip Failed
SBIG CFW8 doesn't report current filter
Camera cooling on re-connect
Falcon Rotator issue
Meridian Flip issue with EQMOD - ASCOM Error
Issues with new SGP 4.1.0.803
Red X in information area
Tracking on Sequence start
Lesvedome Switches Problem
SGP disconnects from Canon 6D when starting sequence
Sequence-associated working images not displaying
PHD2 timing out when using Nikon D5500
SGP not reading pressure, dew point and humidity
EAF & FSQ106 autofocus problems with SGP
Auto-focus starts before mount finishes slewing to target
Capture calibration frames if sequence fails isn't working
Error detail: El servidor RPC no esta disponible, excepción de HRESULT: 0x800706BA
Nudging the mount using Centre Here on an image
Problems with SBIG8300M camera on versión 4
Creating A New Target (Creating events...)
New Version: No HFR… Autofocus Fails
Mount Keeps Disconnecting
PlateSolve2 not solving during sequence
Freezes when centering manually from cog in sequencer
Filter wheel not advancing
AF fails after pre-focus before running sequence
Autofocus on filter change triggered after slew and center on target
Sequence Images fail download after running F&F for any length of time
SGP and FLI focuser connection problems
Abort on switching target - The sequence failed to move to the next event in the allotted time
Phd2 not connecting to SGPro
A quick check on this please
Proper Sequence to launch SGP
Displaying image in Frame and Focus
Main Window Lockup on V 4.2.0.936
ZWO ASI 1600 Pro Fails to save image to disk
Meridian Flip Error - Step 1 only
Can't start sequence - Plate Solver required
Error Msg - Negative Index
Losmandy G11 Meridian flip not working
SGP & Losmandy G11 Maridian Flip Fail
Return Features from 2019 versions
Altair Hyprcam 183c won't save to disk
SGP 3.1.0.403 auto focus runs before plate solve
Frame and Focus not works bin1
PHD2 Reconnect
Alnitak flat man control is not working
SGPro v 4.2.0.1075 and Nikon D750
Cannot access Target Settings in sequencer
AutoFlats won't turn off my flat panel
Generating flats after sequence complete
Observatory startup failed
I can't access the program, it's not responding
Slow startup sgpro
Custom Horizon Ignored During Sequence – SGP Aborted Due to Simple Horizon Limit
FMW Returning incorrect coords on adjacent frame . .
SGP 4.2.0.1129 always says it Warming not Cooling my 071MM-c
Email ntofication of successful sequence
Observatory startup failed, could not open shutter (NexDome controller used)
Centering faile with camera rotation
Failure to plate solve on M33
Auto rotation after plate solve during center
Totally New to SGP using Paramount MX+ and SBIG
First light manual rotation woes
Gain in Equipment Profile Manager
Plate solve camera angle when framing is not 0 or 90 degrees
OGMA Camera Support
Downloading permananent
Ascom alpaca switch
Guide Star Lost, but SGP but SGP did not end the sequence automatically
SGP stops tracking, slews chaotically to an other region, other problems
