so I recently purchased SGPro and installed it. On two different machines (both Win 10 Pro), it doesn’t even start (first start).
OS: Win 10 Pro
SGP: 4.2.0.895 (64-bit)
from first start;
[09/11/22 09:08:58.813][DEBUG][Unknown][NONE] .NET Framework Version: 4.8
[09/11/22 09:08:58.840][INFO][Unknown][NONE] ASCOM Platform version: 6.6.0.3444
[09/11/22 09:09:00.593][DEBUG][Main Thread][NONE] No settings data found, initializing new settings...
[09/11/22 09:09:01.633][DEBUG][Unknown][NONE] FileManager.Serialize: Acquire working file name => C:\Users\Christian\AppData\Local\SequenceGenerator\sgpro_settings.json.working
[09/11/22 09:09:01.633][DEBUG][Unknown][NONE] FileManager.Serialize: Await serialization lock...
[09/11/22 09:09:01.643][DEBUG][Unknown][NONE] Performing serialization of save object...
[09/11/22 09:09:02.419][INFO][Unknown][NONE] FileManager.Serialize: Write to working file took 782 ms...
[09/11/22 09:09:02.419][DEBUG][Unknown][NONE] FileManager.Serialize: Acquire backup file name => C:\Users\Christian\AppData\Local\SequenceGenerator\sgpro_settings.json.working.bak
[09/11/22 09:09:02.420][INFO][Unknown][NONE] FileManager.Serialize: Backup original file took 784 ms...
[09/11/22 09:09:02.423][INFO][Unknown][NONE] FileManager.Serialize: Rename working file to C:\Users\Christian\AppData\Local\SequenceGenerator\sgpro_settings.json took 786 ms...
[09/11/22 09:09:02.424][DEBUG][Unknown][NONE] Serialization took 787 msec.
[09/11/22 09:09:08.010][DEBUG][Main Thread][NONE] Initializing localization resources for en-us...
[09/11/22 09:09:08.133][DEBUG][Main Thread][NONE] Application level exception! : Mindestens ein Fehler ist aufgetreten. (System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
bei ud.a.d())
bei System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification)
bei ud.a(String[] A_0)
and the following;
[09/11/22 09:09:20.250][DEBUG][Unknown][NONE] .NET Framework Version: 4.8
[09/11/22 09:09:20.254][INFO][Unknown][NONE] ASCOM Platform version: 6.6.0.3444
[09/11/22 09:09:24.937][DEBUG][Main Thread][NONE] Initializing localization resources for en-us...
[09/11/22 09:09:24.969][DEBUG][Main Thread][NONE] Application level exception! : Mindestens ein Fehler ist aufgetreten. (System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
bei ud.a.d())
