I was spending time doing Flats for my new ASI1600. In the ASI ASCOM I had set Gain at 76. My objective was do use 76 for LRGB and 200 for narrowband.
First, I only adjusted the per event setting for narrowband at 200 and left every else unchanged. Reading the FITS header info (using Pixinsight), indeed gain was changing from 76 to 200 per filter. However, the e/adu data was the same for all filters and insistent with Gain 76.
I then changed the gain for each event, 76 for LRGB and 200 for narrowband and this time both the Gain value and e/adu values were changed in the FITS header.
Seems odd as I though that method 1) should have worked.
I’m using the latest Ascom from ASI.
