I read through the various posts on Meridian flips failing and I was hoping you can help. It worked the previous night and I can’t think of any changes other than the target. The Meridian flip should have occurred from 11:30 to 12:30, I set up the mount to go 30 minutes past and flip. Even with imaging I can do at least 2 hours so 30 minutes is good. Link to log is here:
What are your settings for the meridian flip? Did you turn on ‘wait for flip’? My guess is you ended up in a scenario where it couldn’t make it, tried to flip afterwards, and hit a limit.
The settings are as follows:Minutes past the Meridian to Flip: 30Wait for Meridian (unchecked)Pause before Meridian Flip (unchecked)Auto Center After Meridian Flip (Checked)Pause Before/Pause After (unchecked)
Try wait for meridian. I’d recommend giving it a try during the day. The whole purpose of ‘wait for meridian’ was to avoid these situations. If you’re going to push your imaging right up to the limits of your mount, you have to give it a buffer to do the flip otherwise it’ll get stuck.
Well… the good news is that this issues has nothing to do with meridian flips… SGPro never even attempted one. The bad news is this:
Your camera ate it during readout of an AF frame
You have identified that SGPro does not protect against a timeout specific to readout
I am not sure how well SGPro can protect against this either. I added a little bit of code to do what we can, but I suspect that we called into the SBIG driver and it did not respond with anything (and blocked the sequence) for 5 hours until we get this:
I downloaded the new drivers they were not up to date.
I was using 120 so shouldn’t be an issue.
I have a new USB cable so hopefully that solves the issue.
I am not using a hub.
As protecting against this again, any way you can put in a 5-10 minute time out? for example no reply from a source stop the sequence?
It’s still happening but I think I know how the time out happens. It’s either changing the cooler temperature or selecting the settings. When I select camera settings I get the time out error right after that. I’m going to bed but I’ll take screen shots showing how I can cause the time out error, but looking through the threads I may have the drivers for an st pro??? I’m going to reload without st and see what happens.
I had technical support from SBIG review my process and also install all the new drivers and he discussed with the other developer and they state that SGP is trying to open the SBIG driver when its already open. SBIG believes it is a bug on SGP. He shadowed me while I recreated the error.
These are steps:
Connect to SBIG camera
Go to Frame and Focus > Press Take one
After Photo Downloads, go to Camera Icon (cheontrol panel on SGP)
On Camera Tab press the Settings Button
Close the Settings Button (press OK)
Get the following error message "SBIG ERROR WHILE ENDING EXPOSURE: DRIVER_NOT_OPEN
That’s weird. What camera are you using? I have an STF8300M and it doesn’t have any issues. I use frame and focus all the time. I updated my drivers about a week ago.
That is really strange. I wonder what yours is doing differently from mine. Like you said, you’ve tried the obvious… different USB ports, different cables, etc…
I wonder if my camera is, for whatever reason, handling it differently.
If you shadow me I can recreate it at will. I had the SBIG tech guy shadow me, he read the log and after reviewing the log, he stated SGP sent a command to open the driver for the SBIG camera when it was already open.
