Hi guys, just installed lastest version (4.2.0.900) but the focused procedure simply stop working. I can see starts in the pictures of the procedure, but no HFR data is detected, so, the procedure fails. No changes since last use in any, parameters or physical stuff (dedicated observatory). Any tip?. Anyone using this version with positive results?
I installed 4.2.0.900 tonight and the autofocus worked for me first time. Currently running APPM with SGP as the camera interface, but will be back to imaging and autofocus afterwards and will check to see if there are issues like this.
Hi Stan, one question, what did you do to revert the version?, just download and install it over?. I’m afraid to lost my local settings if I need to remove the current version first.
We’re more than happy to take a look at what’s going on with this issue, but since all of our internal Auto Focus tests are passing, we’d need logs to see what’s happening. Even if you reverted to 4.1, the logs are still present and can be found using the issue reporting tool. More guidance here:
