The program started to hang on loading after I saved some sequences. It says opening sequence, but the progress bar is slow and fails to complete. Where are the files so they can be deleted?
Peter Bresler
Peter Bresler
The sequence would be where ever you saved it to. As for files this will depend on what version of SGP you’re running. In general you can find most things under:
C:\Users\YOUR-USERNAME\Appdata\local\SequenceGenerator
Also a log may be helpful if one is being generated:
More info here on resetting:
Resetting really would not work because the program would not even load.
I did find the location of the sequence files; deleting them solved the problem.
The program needs an error handling routine when it loads its files so that does not happen.
Peter
In a message dated 11/24/2019 6:40:05 PM Pacific Standard Time, forums@mainsequencesoftware.com writes:
Depending on what version you’re using there is that logic in there. But it was only recently added in the beta.
