I am struggling to get my new camera/filter wheel QHY163M/QHYCFW3 to work with SGP.
The camera appears to connect correctly and operate. But no matter what I try I cannot get the filter wheel to operate. Initially when connecting: SGP report the filter is moving then reports NA. All the time there is nothing from the filter wheel (no movement or LED).
I have downloaded the latest camera drivers and Ascom (4pin) drivers but still no joy!
The filter wheel is connected to the laptop via the camera 4 pin connector. and switched to that mode ie green status LED.
At one point it did start to work, but after restarting SGP i’m back to no filter wheel movement.
I have tried switching the filter wheel into USB mode (with all the drivers installed) but still no control of the filter wheel.
I know the hardware is all OK because it works flawlessly in EZcapQT.
I also have Kstars/Ekos setup on my old laptop and again the camera/filter wheel works fine.
I have looked at forums on the internet and see other people have also had problems, but I can’t find a solution.
I have even tried wiping my Dell Latitude laptop and doing a clean install of Windows 10, ASCOM Platform 6.4SP1, SGP and camera drivers but still the same
I have run out of things to try…
There must be people who have managed to get this setup working?
Any help would be greatly appreciated.
