Red X in information area
I’m getting a red X down in to bottom of SGP where it tells you about integration time and information about the equipment status and I get the red X if I right click on the gear symbol next to target information in the sequence tab. I’m running SGP 4.1.0.809. Can anyone help me with this issue?
TIA
That is likely from a resource (memory) leak. Can you reproduce it and send logs? Screenshots of the issue may also be helpful so we can make sure we’re talking about the same thing.
Thanks I just sent you the information and log with approximate time. I’ll be imaging again tonight and if it happens again I’ll note the time and take a screen shot and repeat your procedure.
