Dear all,
I will using the fallowing equipment for my astrophotography and I already check SGP forum for those equipment’s compatibility, but I do still have some questions:
SBIG STC-7 CMOS Camera (Do I need to install MaxIm DL in the same PC or I can just install SGP without MaxIm DL and SGP can native control this camera without any issue? Cause, I am going to purchase this camera new and I am worried about the camera’s warranty if SGP cause some hardware issues. Moreover, I couldn’t find any answers in this forum: SBIG STC-7 and other new SBIG cameras? )
ZWO ASI 290MM MINI CMOS (This is the camera for guiding and should work well with SGP via PHD 2 / ASCOM, however, still want to double check with you guys about this equipment’s compatibility with SGP.)
Takahashi EM200 Temma 3 Equatorial Mount (This is a new system, not the old Temma 2, so please help me check the compatibility with SGP if you can.)
Software Bisque The Sky X Pro (Do SGP can synchronize with The Sky X Pro for Takahashi EM200 Temma 3 mount’s GOTO control, cause The Sky X can control the mount or do I need to manually copy a target’s coordinates from The Sky X Pro to SGP and SGP will control the mount to the target? P.s. If question three is ok.)
Alnitak Flip-Flat (Integration / Illuminated issue, has the problem been solved? Alnitak Flip-Flat, SGP Integration Issue - #2 by Jared )
Please reply to this topic if you have time, cause those equipment will or “might” arrive in the end of this year 2021.
P.s. English is my second language, if you see any spelling / grammatical error please don’t mind it.
Best regards to all,
Superz
