Just a thought from my use of the F & M wizard. Would it be possible to grab a corner of the target rectangle in order to rotate it. This would facilitate orienting the target object in the field. Currently I do this by changing the angle in the dialog until the Target rectangle appears as I want it, but this would be so much easier if it were possible to grab a corner and rotate around the centre.
thanks for considering,
Paul
