Sequence Generator Pro 2.4 is officially released! While you don’t need to read through every single change, we ask that you read at least sections 3 and 4 in order to prevent problems after install. A big thank you to everyone who helped get SGPro into a better state. Enjoy!
What is Sequence Generator Pro?
Sequence Generator Pro is best-in-class capture software designed to meet all your imaging needs. We support all major camera types (including SBIG, QSI, Atik, Canon, Nikon and more) along with hundreds of other devices from filter wheels to domes to camera rotators. Enter the details of your sequence (frame counts, duration, types, etc), click run, and relax while SGPro captures your data! Our fully automated capture suite will assist you with complex multi-target sequence creation (including complex mosaics), collect all your data, keep you in focus, communicate with your auto-guider, recover your sequence from many environmental conditions and will even conduct an automated meridian flip. Even better, this is all done while you are asleep!
Sequence Generator Pro is appropriate for beginners and pros alike. It is easy to use and powerful enough to meet the needs of almost any astrophotographer. If you haven’t checked it out, we offer a free 45 day trial (with no restrictions). Check us out at www.mainsequencesoftware.com!
2.4 Non Feature Changes:
- Dropping support for PHD1
- PHD2 Users: While the released version of PHD2 is stable, SGPro relies on some yet unreleased features. As such, you will be required to download and use a stable, but not yet released version of PHD2. You must download version 2.4.1e or better from the developer snapshot page here.
- Must be using ASCOM 6.1 SP1 or better
- As of this release, SGPro 2.3 and earlier are no longer supported (your sequences and profiles should carry over fine, but we will no longer receive support requests from earlier versions. Note that SGPro 2.2 sequences are not compatible with SGPro 2.3 or 2.4)
Is SGPro 2.4 Compatible with My Operating System?
Compatible Operating Systems for Canon Users:
- Windows 8.1 (32 or 64 bit)
- Windows 8 (32 or 64 bit)
- Windows 7 (32 or 64 bit)
Canon users may no longer use Windows Vista or Windows XP.
Compatible Operating Systems for All Other Users:
- Windows Vista
Windows XP is no longer supported under any circumstance
Feature Changes
New SGPro Notification System
- This is the latest add-on in SGPro… With it you can monitor your sequence’s status, warnings, errors and alerts using Email, Text (SMS) or Good Night System. You can get a remote notification on the status of just about anything you can think of (e.g. centering failures, PHD2 star lost, and many more…). This means that you will be able to monitor the status of your sequence through email or GNS (but most importantly through any type of smartphone). With it you will know if your sequence has stopped prematurely or if something might be wrong (clouds, wind, etc). Full details and instructions can be found in the included help file. The cost for this addon will be $19 and it can be purchased here.
Weather Stations
- Initial implementation for weather stations (ASCOM safe / unsafe). Auto park, close observatory and perform other end of sequence options when an unsafe condition is reported.
Auto Focus Changes
- Smart Focus
- Auto continue when you are still outside focus at the end of your run
- Reset the focus run farther out when you start the AF run inside of focus
- Best fit method. Use all of your data! Auto focus will now perform a linear regression of your focus data in order to arrive at a more accurate focus position.
- Whole image HFR star cap. Prevent SGPro from trying to use more stars than you have available in your FOV (sometimes leading to noise dominated HFR values).
- If you have a scope with a central obstruction, you can also turn the “Smart Focus” feature off. Scopes that produce “donut” stars when severely out of focus tend to operate better without this feature.
- The cancel button for auto focus will now cancel all auto focus activity during that session (and not just from the last run)
- Added an option where auto focus dark frames only need to be with +/- 2sec of the exposure length to be applied (the closest match to the actual exposure time will be selected)
- Added direct access to auto focus filter exposure times from the auto focus settings dialog
- Fixed an issue where users using backlash compensation during auto focus would experience intermittent failure
- HFR calculations for very large images should be much faster
- Removed auto focus option to use same stars
Mosaic and Framing Wizard Changes
- Added a new feature to the Mosaic and Framing Wizard that allows you to fetch the mosaic canvas from an existing SGPro FITS file. The mosaic canvas will be centered on your image and a blue rectangle drawn about the area your import occupies (then you can know where to add additional mosaic frames).
- You can now create a sequence from the Mosaic and Framing Wizard that Auto Center, Slew or do both for each target
Sequencing Changes
- The sequence will now attempt to calibrate PHD2 and start guiding for you (if it’s not already running or you don’t have a valid connection to PHD2)
- Adding new entry to the “Event Options” menu that allows the user to set the current (starting event)
- Added ability to provide a “global end time” for all imaging. This will take priority over any target specific end times.
- Added an option to the auto guider tab that, if checked, will force the PHD2 auto guider to recalibrate on target change
- Added option to stop the mount in place (stop tracking) when the sequence terminates (as opposed to park)
- Delayed sequence start options
- Wait until camera cools to start sequence
- Camera will not cool until near image start time
- Keep observatory closed until sequence starts
- Removing option to pause the guider during main image download (this never worked properly anyhow)
- The default ISO for new DSLR sequences is now 800
- Fixed a bug where resuming a sequence could sometimes trigger auto focus when you do not have that trigger selected
- Fixed a bug where aborting the sequence with “rotate through events” selected, would move to the next event upon resuming the sequence
- The auto guider will now always attempt to “settle” prior to taking a light frame (even if the dithering option is not selected)
Plate Solving Changes
- Blind solves will now send scale and error of 100% (you can override error in ANSVR settings). ANSVR, when used as the primary solver, still sends the scale with 5% error. This allows blind solves to be truly blind (or it allows you to customize the blind solve error via ANSVR settings)
- Changing the way we use Elbrus to plate solve (hopefully more reliable)
- Fixed a bug that would crash SGPro if the target settings dialog attempted to plate solve a non-16 bit FITS image.
- Fixed an issue where non-FITS images could not be blind solved in target settings
- Added support for additional Pinpoint catalogs (GSC, USNO and UCAC variants)
Sequence Recovery Changes
- Recovery will no longer attempt to center and restart guiding if you did not originally center on that target to get there
- Guiding and settle timeout now set at 15 minutes (from 5).
User Interface / Experience Changes
- Added connect all equipment menu item
- Added keyboard shortcuts to connect and disconnect all equipment (Ctrl+Shift+C and Ctrl+Shift +D)
- Added a notes system to the equipment profile so you can remember why you created it!
- Added all keyboard shortcuts to a help dialog for quick reference (under the help menu)
- Added “Bad Image” marker as prominent icon in the upper left hand corner of an image (when user marks image as bad).
- Sequencing Window and Control Panel buttons (and keyboard shortcuts) now toggle these dialogs (instead of just open them)
- Custom profile location (great for keeping your profiles in a known location… easier for transport between machines)
- Fixed a bug where Canon image previews could sometimes appear in the “portrait” orientation
- Fixed a bug that would allow the camera to be manually disconnected during a sequence
- Fixed a bug where the event in-progress arrow would disappear when clicking on other targets
- Fixed a bug where image history review (back and forward arrows) did not consider image types other than FITS
- Disabled image history navigation during image download
Misc Changes
- Added support for various QSI fan modes (including quiet mode)
- Full support for PHD2 using new API (a much more stable method than what was used for PHD1)
- Adding scope focal length field… adding to FITS header
- Fixed broken AstroPlanner imports
- Fixed a bug where an image download error could cause the flats calibration wizard to fail badly
- Fixed a bug where TEC cool-down on camera connect would fail if the cool-down period was 0 minutes
- Better user feedback for mounts that don’t support flipping before the meridian.
- Fixed a bug that would not allow event scripts to be run if the path contained spaces.
- Fixed a bug where aborting a sequence during the guide and settle process would present an error dialog indicating sequence failure
- Fixed a bug that would not allow users to open sequences by double clicking SGF files if the sequence file name contained spaces.
- Conforming to CCD-TEMP and SET-TEMP FITS header formats
- Removed the “ASCOM Chooser” entry from all equipment types
- Updated Canon SDK to the most recent version (2.15)
- The manual rotator direction can now be reversed if your profile has a gear combination that causes the image to be “flipped”
- Better internationalization
- Fixed a bug that when using the SBIG SGPro API guider, would cause PHD2 to crash in regions that use commas as the decimal separator
- Fixed a bug where “settle distance” for PHD2 did not work in regions that use commas as the decimal separator.
- Many, many small bug fixes
