Sequence Generator Pro 4.1.0.765 is Released for General Use
Sequence Generator Pro 4.1.0.765 (32-bit and 64-bit) is Released for
You can find it here:
Sequence Generator 4.1.0.765
Additions
  • Themes! Choose from 5 different options: Light, Dark, Black, System or Follow Windows.
  • Target tooltips: Almost all the information you could want all without having to open settings.
  • At-a-glance Target Status Indicators: See if a target is set to slew, center, rotate or end at a set time. These indicators are now always visible and a great way to double check settings before starting.
  • Extended Target List: Great for sequences with lots of targets… three times as many targets can be seen in this view.
  • More target rotaion options. Set your camera rotation based on the rotator’s mechanical or target’s (sky) angle.
  • A more useful toolbar (with customized visibility options).
  • Switch profile portability. Edit sequence switch states on any machine even if that machine does not have the correct drivers installed.
Changes
  • Way better layout and feedback for a target’s altitude and time parameters.
  • Switches refactor (SGPro no longer attempts to connect to all switches, only those that are required). Many general improvements in how switches are handled.
  • Sequence background loading improvements. Faster, more stable and way more user feedback.
  • The Create Sequence dialog in the Mosaic Wizard is now less difficult to see.
  • GNS implementation overhaul (will now use your installed version of GNS)
  • Improved image history tooltips
  • Minor overhaul to the flats calibration wizard (no longer dependent on the sequence’s gear; better math to arrive at the desired ADU level faster)
  • Tooltip, warning and error message overhaul
  • Significant reduction to probability of file corruption in saved data
  • Minor changes to the Equipment Profile Manager layout.
  • Many different tiny Quality of Life oriented changes
Fixes
  • Fixed several issues that would cause SGPro to misbehave with truly gargantuan sequences.
  • SO… MANY… BUGS… SMASHED. Too many to list here.
