Hello all,
I frequently setup multiple targets for a given night and run into an issue at times where if there is a time gap between targets the sequence slews to the next target before the start time that I have set. It then fails to center since the scope is pointing at trees or some other obstacle. How can I et the sequence up so that it waits until the start before it slews and centers on the next target?
It’s very hard to tell exactly what is happening from descriptions of problems, but if you’d like to send us logs showing the issue you describe, they will likely lead to a pretty quick answer.
Thank you Ken for your reply. I did another run tonight and the problem did not occur. If it does repeat I will get the logs and drop them in the correct location.
