SGPro 4.5.0 Alpha Available for Test
Hi folks,
The SGPro 4.5.0 alpha is here for purposes of testing and user feedback. This thread is the only place to get it. We want to make sure that using 4.5.0 is an intentional action and not a surprise granted to users who just go through version update actions as a force of habit.
Some notes:
  • Never use alpha or beta SGPro releases without backing up these threee things:
    • Any sequences you inntent on opening
    • Any equipment profiles you intend on editing (better back them all up for this release)
    • The entirety of the SGPro settings folder located at: C:\Users\[username]\AppData\Local\SequenceGenerator
  • I’m sure I forgot something but, in general, the 4.5.0 change set is here:
    SGPro 4.5.0 is Code Complete - Sequence Generator - Main Sequence Software (sequencegeneratorpro.com)
  • SGPro 4.5.0 does not yet have updated documentation. That said, if seasoned SGPro users are not sure how to navigate these changes, we may want to reconsider something. Most should be self-explanatory.
  • A special note for ā€œswitchā€ users: sequences opened and saved in SGPro 4.5 may be opened by previous versions of SGPro, but your switch settings will not be present (see note 1 above). SGPro 4.5 moves to a much more reliable save state for switch data and it is automatically migrated to the new format on open.
Downloads:
In the camera setup section, I don’t see the field for the scale ("/pixel). Is that no longer needed?
This is because it’s not really a property of the camera and, as such, has been moved to the Plate Solve tab.
Also, if you’re inclined, you can give settings search a try and see if it leads you to it.
I see it now. It took me a while to figure out how the search worked. I realized it highlights sections with flashing box(s) :slight_smile:
I did encounter a problem with using the profile manager. It happened 3 times so I’m backtracking to see what steps I made to cause it. I’ll let you know when I find the steps to duplicate the error and will include a screen shot and the session log. As a work around, if I run File → Save Sequence as Profile, the profile gets restore and is usable.
Tonight, I’ll be able to run an actual sequence.
Do you want us to post issues here or start a new thread?
A definite issue is SGP V5 hangs when attempting to open the ā€˜Configure External Notifications’ window. This happened 3 of 3 times. I tried to upload the log file using SGP’s ā€˜Report a Problem’ but after filling out the issue and attaching the log file, it failed to submit the case.
Addition-
When doing a periodic recentering step, I assume the auto guider would be in the paused mode. It was still actively guiding while auto centering.
Resizing the new Control Panel doesn’t work using the bottom of the panel, but does work from the left, top, and right sides.
Also, resizing doesn’t rearrange anything like a web page does, instead, it simply makes the window smaller or larger, adding scrollbars as needed.
For example, the ā€œFocusā€ page has 6 panels, but widening the Control Panel doesn’t move the partially-hidden bottom two panes to right of the top 4 panes.
A few issues with the Control Panel’s ā€œEnd sequence no later thanā€ and the Sequence Settings’ ā€œEnd Sequence atā€ boxes:
  1. They were both 00:00 but in the prior SGP release they were 05:49.
  2. The field names are slightly different. Are they the same thing? I interpret ā€œno later thanā€ as being different than ā€œatā€?
  3. I can set them to different values, although they eventually became synced.
Still no sky quality metric for a filename parameter
Not sure if my issue got logged through the SGPro interface, so thought it best to post here in case.
Setting Profile as default in 4.5 destroys the profile on reload of SGPro
In Profile editor, right clicking on a profile and setting a profile as default destroys the profile. On restart, SGPro will fail to load the profile with the below error:
Profile load error
Profile manager shows:
Opening the profile in notepad and changing ā€œbDefaultā€: true, to ā€œbDefaultā€: false, and restarting SGPro 4.5 restores the profile.
That error I have definitely seen. The work around I found that works to clear that for future restarts was: File → Save Sequence as Profile, the profile gets restored and is usable on the next start of SGP.
Was that in 4.5 Alpha or previous versions?
I’ve not had this specific issue in the 4.4 versions, just in this Alpha version.
I’ll give your workaround a try in this 4.5 Alpha to see if works for me.
Thanks.
This happened in the 4.5 version.
It matters not to me… whatever you’d like is OK. Especially if reporting issues from the SGPro app itself it may be easier to just create new issues.
I am not sure about this one… I will investigate. I also cannot produce a hang, but I can sometimes produce a situation where nothing happens at all.
Logs would be helpful here. I just watched a centering here and the guider behaved as expected. Is it repeatable?
I’m working on this… The status bar at the bottom is swallowing the mouse messages for the window.
There is no intent on implementing a reflow-based layout. It would take forever and it wouldn’t provide anything all that valuable valuable. The only reason it’s resizable now is because the current method was easy and folks that have lots of switches appreciate the ability see mor of them at one time.
Thanks, I have this marked for investigation
They are the same and currently I am thinking that the older sequence settings panel will just go away in favor of centralized settings.
They are designed to sync pretty immediately. I’ll see about this.
Yes, the issue was submitted successfully. I’ll have a look at this.
Thanks for your help here. I do very much appreciate it and will work to turn these around over the weekend.
I can reproduce this at will on both Window 11 PC’s running SGP V4.5
The first time this was encountered, there was an active image capture taking place.
This led to the session hanging with a spinning circle and the screen faded out with a program not responding eventually displayed. Looking at the task manager, SGP CPU usage dropped to about 0.1%
On the other PC, when ā€˜Configure External Notifications’ was selected with no other activity taking place, it appeared nothing happened but when I attempted to click on any other area, that is when the screen fades and SGP hangs. I also verified nothing is entered in the SGP log during the time when it hangs.
Regarding the auto guiding (am using PHD2) not pausing during a periodic recentering, it was repeatable that night. The next two nights, with the recentering feature disabled, SGP 4.5 ran flawlessly for the 6-hour session. I’ll verify tonight and let you know the results either way and grab the log.
Thanks!
Global end time keeps defaulting to 00:00, I set to 06:10 and when I reload the sequence the following day it has set back to 00:00
I have noticed this as well several times.
Tonight I’ve also encountered both these issues that Mike has mentioned above.
  • SGPro hangs when attempting to use the Configure External Notifications feature
  • Autoguider (PHD2) continues to guide, however, this was during an attempted recenter during a Reactive Recentering when location error > n pixels
The Camera Cooling progress bar does not show or progress:
I have my camera set to cool to 0C in 10 min, but the progress bar never shows
I have had no luck reproducing this or anything similar. Coupled with the fact that @MSiniscalchi finds the issue to be intermittent, I think my only hope of finding it will be logs if you have them.
