I have been running SGP for about a year now, and now I’m having trouble running SGP on my windows laptop. I have used this laptop all the time for SGP. I tried uninstalling it and reinstalling. It still won’t run. Not sure what the problem is. Any help would be greatly appreciated.
First off you should check if a log is getting generated to see if there are issues. You can find the logs here: C:\Users\<YOUR_USER_NAME>\AppData\Local\SequenceGenerator
Next you can try to reset using the following command: c:\Program Files (x86)\Sequence Generator\Sequence Generator.exe /reset
If that doesn’t work you can get a little more serious:
Hi Jared,
Yes ASCOM is installed. Not sure about .net 4.8.
Not that am aware of. I had an issue with it not reading my focuser the last time I tried to image. But I troubleshoot that and that got fixed. I’m up in Canada so we have not had many clear nights. Last night I just wanted to set up a sequence and when I clicked on the icon it did not open. I’m not sure what version is running. I’m away from my laptop at the moment but I’ll send you what you need in a few minutes.
Hi Jared,
Here is the latest log generated earlier today.
[01/27/21 11:41:27.512][DEBUG][Unknown][NONE] .NET Framework Version: 4.8
[01/27/21 11:41:27.616][DEBUG][Unknown][NONE] Application level exception! : Unable to open ephemeris file: C:\Program Files (x86)\Common Files\ASCOM\Astrometry\JPLEPH, RC: 1
at ASCOM.Astrometry.NOVAS.NOVAS31…ctor() in C:\ASCOM Build\Export\ASCOM.Astrometry\ASCOM.Astrometry\NOVAS31.vb:line 107
at ASCOM.Astrometry.AstroUtils.AstroUtils.InitialiseAstroUtils() in C:\ASCOM Build\Export\ASCOM.Astrometry\ASCOM.Astrometry\AstroUtils.vb:line 46
at ASCOM.Astrometry.AstroUtils.AstroUtils…ctor() in C:\ASCOM Build\Export\ASCOM.Astrometry\ASCOM.Astrometry\AstroUtils.vb:line 35
at SequenceGenerator.Astrometry.d()
at te.a(String[] A_0)
Let me know if you need anything else.
Miguel
