I have not used my rig for a while, so last night I had clear skies for a Change and set up a session.
When trying to “Run Sequence” SGP came back with a message saying that I had to remove the Wanderer Flat Box manually. This is new, as I’ve had this box connected for at least two years without ever having to open or close it manually. SGP does connect to the Flat Box and also recognises the status but I cannot open or close the box from SGP.
Would very much appreciate it if you could take a look.
Link to Logs
Approx time of issue: 18:00
Useful Info
OS: Microsoft Windows 11 Home Ver: 4.5.0.1649 (32-bit) .NET: 4.8 ASCOM: 6.6.1.3673
I just updated SGPro and nothing else as it all worked fine the last time set up the scope.
Basically, in SGP the box is connected and shows the correct status(open or closed). At the beginning of the sequence it’s closed and when I issue the “Run Sequence” the box normally openes automatically. Now, instead of doing that, a message pops up treating the box as if it were a manual box and I need to switch to the Wanderer app, manually open the box and then return to SGP to click “OK”, after which SGP continues with the sequence.
This then results in the fact that at the end of the sequence, the box does not close automatically and I cannot automatically gather any flats I might want.
The message I get is not the one you mentioned above, in fact, it’s not an error message at all.
Even when I connect the box manually, SGP does recognise the box and the status but not the fact that it’s an automatic box.
Finally found what was causing the issue, adding this comment in case someone else runs into the same thing: Control Panel → Flat Box → uncheck “Prompt to place flat box”.
